Samsung Galaxy S GTI9000 Smartphone Logo
Posted on Nov 23, 2017
Cannot connect ti Wi-Fi. Message says obtaining ip address but as soon as a remembered message on wi-fi network, wi-fi disconnects and starts scanning again. This process repeats itself but never connects to the wi-fi. I have followed samsung's advice by removing the sd card and battery but this has made no difference.
Raymond Ramrez
Level 1:
New Friend:
  • Contributor 56 Answers
  • Posted on May 18, 2019
Raymond Ramrez
Contributor
Level 1:
New Friend:
Answers
56
Questions
0
Helped
8866
Points
87
Do you have other devices such as tablets, notebook, PC, or smart devices on the same Wi-Fi network? Do they have a similar problem?
Try logging on to a different Wi-Fi network such as free services in some shops and stores. If you cannot connect anywhere, your phone may be bad.
5 Related Answers
Anonymous
  • 48 Answers
  • Posted on Feb 10, 2008
SOURCE: about wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Anonymous
  • 31 Answers
  • Posted on Oct 11, 2008
SOURCE: Wi-Fi SD card
Hey, id be happy to help :), the reason why your SD wifi card is not getting read by your pocket pc is because. The wifi card you have is probably have was made for a regular computer and is not compatible with your pocket pc. Id recommend for you to find a SD wifi card that is compatible with your pocket pc. And return the one you have now, thanks and I hope this helps!
Silverblade
Aris C.
  • 173 Answers
  • Posted on Nov 05, 2008
SOURCE: Wi-Fi problem Toshiba A15-S157 laptop
If your laptop has a di-fi switch/button chances are you have one integrated on the main board of the laptop, check if the wi-fi adapter is installed properly by going to the Device Manager and check Network Adapters normally a wi-fi adapter will show up if not check if you have any devices listed under network devices(Network Controller, Ethernet Controller). Now if the wi-fi card is installed and the status on the Device Manager say's that it's working properly, you may now check your laptop for a 3rd pary wi-fi utility/application that manages your connection look for it on the System Tray on the lower right hand side near the clock or go to all programs and look for any WLAN utility, when you open the utility make sure the wi-fi radio is turned on or enabled.
Anonymous
  • Posted on Jul 02, 2009
SOURCE: i can not remember my wi-fi password. i need it to
If you have tried the default passwords (blank, admin or sysAdmin) and they don't work, you will need to reset it back to factory settings. You can do this by finding a hole at the back of the unit and pressing the hidden switch there for a few seconds. After that it should be back to its original configuration. You will obviously have lost any changes you made to it since you took it out of the box.
Anonymous
  • 436 Answers
  • Posted on Sep 12, 2009
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
2answers
My IP address says unavailable and I can not connect to WiFi . how do I make it available again ?
Turn on the Wi-Fi and connect to a network. Long press on the connected network and select Modify Network. On IP Settings drop down menu, select Static. Assign IP of your choice but leave other variable untouched.
How to Fix Failed to Obtaining IP Address Error in Android
Method 6: Assigning a static IP address
  1. Go to Settings > Wi-Fi and long press on the network that refuses to connect.
  2. Tap on Modify Network.
  3. Scroll down and make sure the Show advanced options box is checked.
  4. Change the IP settings to Static.
  5. In the IP address field, change the last octet with any number from 10 to 255.
More items...
13 Sep 2018
Fix: Failed to Obtain IP Address - Appuals.com
To give your computer a fixed (static) IP address:
  1. Open the Activities overview and start typing Network.
  2. Click on Network to open the panel.
  3. In the left pane, select the network connection that you want to have a fixed address. ...
  4. Click on IPv4 or IPv6 in the left pane and change the Addresses to Manual.
More items...
Create a connection with a fixed IP address
When a malfunction arises the device fails to obtain an IP-address within the available network. Your device disconnects the network automatically, then tries to connect once more to obtain an IP-address again. The attempts don't stop. There are several reasons which cause the "Obtain IP Address" error.14 Oct 2017
How to fix when Wi-Fi is stuck "Obtaining IP Address"?
IP Configuration Failure: Your router may be failing to assign a proper IP address. Usually, this issue can be solved by simply restarting the router. You might be in a poor network coverage area: Shift your device to the area where the network signal is good.
Tell me how i resolve dns failed connection
ou can try these options. Please follow step by step instructions on your phone.
A. Reset Wi-Fi:
  1. Delete all the configured wireless connections.Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Click on Forget
  3. Do this for all your connections
  4. Now Enable Wi-Fi again. And connect to router.
B. Using Static IP Address:
  1. Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Make sure to disconnect the network if connected.
  3. Now open the network,
  4. Select Static IP
  5. Now you can assign IP Address
  6. Here are default ips (It may vary according to your router)
    IP : 192.168.0.2 or 192.168.1.2
    Subnet Mask : 255.255.255.0
    Default Gateway : 192.168.0.1 or 192.168.1.1
    DNS: any two of these =>
    • 4.2.2.5
    • 4.2.2.1
    • 208.67.222.222
    • 208.67.220.220
    • 8.8.8.8
    • 8.8.4.4
For screenshots visit http://www.samsungbadaapps.com/tips/dns-failed-error-on-wi-fi
Wi-fi not obtaining IP address and if turn off wi-fi can not get to turn back on
Assuming you're trying to connect via wireless router. If you connect, but then aren't able to get to the Internet. I would something is wrong between the router to the modem to the wall (DSL/Cable modem) rather then your tablet device. You can connect your device to your router and you device will show it has a wifi connection, but beyond the router something may be amiss. Try seeing what you get from another device like computer or laptop. That might get you closer to your actual issue,
My wifi stop working,i dont know why???
Solutions to Common Android WI-Fi ProblemsFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up. I usually fix their problem after few troubleshoots but today while I was fixing a problem on my device, I realized that it could happen to any one - even to my readers on Guiding Tech. Hence we are going to discuss four of the most common Android Wi-Fi problems and see the probable causes and solutions to them.
Android Cannot Scan a Wi-Fi Network Reason
There may be two reasons as to why your Android cannot scan a network automatically. The first reason may be that the network you are trying to connect to could be Ad-Hoc in nature. As most of the Android phones are not configured to work on Ad-Hoc networks but on access points, they don't scan them.
The second reason may be that the Wi-Fi network you are trying to connect to might be hidden for security reasons.
Solution
By default, Android does not support Ad-Hoc Wi-Fi network but many developers patch the wpa_supplicant file on Android in order for them to work. If you do a quick Google search you will be able to find if there's a fix available for your device but the fix can only be performed on a rooted phone. Furthermore, don't forget to back up your original wpa_supplicant file if at all your phones goes into foreclose or boot loops.
If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
Wi-Fi Keeps Disconnecting Frequently Reason
The most obvious reason for the problem may be with the Wi-Fi Sleep Policy which disconnects your Wi-Fi every time your Android goes to sleep to save your battery's juice.
Solution
To manage Wi-Fi Sleep Policy, open Advance Wi-Fi settings on Android and tap the option Keep Wi-Fi on during sleep. Here, check the option Always to enjoy an uninterrupted connectivity, but you will have to compensate it with your battery life.
If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
Obtaining IP Address Infinite Loop Reason
I don't know the exact reason behind this, but it might be a bug in Android. I have seen many people getting this problem, and it gets kind of annoying when the problem does not gets fixed even after restarting the device.
Solution
First of all, you must restart your Wi-Fi router and see if that helps. Many people say that resetting the phone to factory state works but that's not an appropriate solution. Wi-Fi Fixer is an amazing Android app that can help you here. The app resets your Wi-Fi system files (same as when you reinstall the Wi-Fi drivers in Windows, or you disable and enable the Wi-Fi adapter) and services and helps you to connect to the network and obtain the IP address.
Solutions to Common Android Wi-Fi Problems
Ads by Google
    wifi-router.pngFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up.
    Solution
    ad-network-manually.png If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
    Solution
    Ads by Google advanced-settings.pngkeep-wifi-on.png If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
    Solution
    wifi-fixer.png If you know the range of IP address the router is broadcasting, you may configure your Android to use static IP address while connecting to the network.
    Can't Connect to Internet using Wi-Fi Reasons
    There may be several reasons as to why you are not able to connect to the internet even when you are connected to the Wi-Fi. The reasons may be:
    • The router is not broadcasting internet services.
    • The IP address or the gateway is wrong.
    • Problem with the DNS settings.
    Solutions
    You may use another device to check if the router is actually broadcasting internet. Also you can configure the IP address, the gateway and DNS manually to connect as their might be problems with DHCP.
    Conclusion These are pretty much most of the Android problems one might encounter on his device and the probable solution one can try to fix the problem. I don't guarantee that you will fix the problem but it's a good start nonetheless. And most of the solutions should work actually.
Thanks .
Sep 03, 2013 • Cell Phones
1helpful
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
3helpful
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
2helpful
2answers
I cant connect to WiFi with my blackberry bold. it shows "Failed to obtain an IP address"
Hi, this issue is caused when message authentication code (MAC) address filtering is enabled on the Wi-Fi network, and the MAC address of the BlackBerry smartphone is not accepted.
To resolve this issue, add the MAC address of the BlackBerry smartphone to the accepted MAC address list for the Wi-Fi network.
I hope this information may help you to resolve the issue.
2helpful
2answers
Having troble connecting to internet, an it has to do with the computer
try to turn off your wifi button then turn it on after 1min. or go to network connection and check your ip, it should be obtain the ip address automatically.
2answers
Psp connection to internet
You probably have your wi-fi under secured network.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
