Toshiba satellite a100,wa-1 memory upgrade
Take out all the memory cards and wipe the gold part of the memory modules.
Then insert the two 512 modules & check the memory.
If it shows the correct readings, then the two modules are detected.
Then insert the 1 gb & other one 512 module.
Then use the other one gb with the same 512 & check if it shows the correct readings.
Then the two 2 gb modules are fine.
Now insert the two 1 gb modules & check now.
There are ECC type & non-ECC type memory modules are available, chck which one your computer supports & which type you have.
If it shows the correct readings, then the two modules are detected and fine.
Then you can also swap the slot and check if any memory module is not detectd correctly.
Some have four slots & i dont know how many slots your laptop have.
Good Luck.
Live, Love, Laugh.
