There are a number of places where the water leaks out. There should be a plate in the back that you can remove. Then put the machine into the fill position and look with a flash light. You should be able to find the leak that way. There are several hoses above the drum; any one of these could be leaking
Sounds like a leak either in the bottom, connector or water valve for your water inlet line. Visually finding the leak is your best bet, then you know what parts are to be replaced.
SOURCE: tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
SOURCE: I have a maytag neptune MAH5500BWW. Everytime the
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
