Some laptops
have issues with Windows XPs hibernation mode. To get the computer back
up again you should just hold the power button down until it shuts off
completely. Some laptops won’t shut off even if you do this. When this
happens you have to take the battery out to get it to turn off. Make
sure it is not plugged into the wall when you do this otherwise it wont
work.
Once you get the computer back running again you may
want to disable hibernation if it seems like its going to keep
happening. Go to Start, Settings Control Panel or Start, Control Panel
and go to the Power Options icon. Change the hibernation section to
never. You may want to try standby as an alternative. Standby saves all
your running applications and documents into RAM while hibernate saves
them to the hard drive. Hibernate uses less power from your battery,
but it will take you considerably longer to get the computer back up.
If you always plug the computer in then you may want to disable standby
and hibernate since you really dint need them while plugged in.
Let me know if this works.
