You can download a copy of the user manual for this camera so you will be familiar with it and will be able to use it fine, just click HERE and proceed with the download.
It sounds like the camera just needs to be restarted. It might be an update that needs to be completely installed. Otherwise, some of the settings must just need to go back to default.
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera. 2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Lens cover not close, This will happens due to two reasons.
or
To resolve the problem. first check battery on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Rating the solution is highly appricaited...Good Luck.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
Follow the instruction to retract camera lens:- 1) Turn on your camera. 2) Press the Playback button on the back of your camera. The lens on your camera should retract.
First off I need the make and model of the camera. A lot of camera's don't have this feature. Depending on the quality you need. You may want to consider researching a camera for your needs Thanks, Lee
QUESTIONS! ONE, DOES YOUR CAMERA HAVE A SOFTWARE DISC WITH IT? AND TWO, HAVE YOU ATTEMPTED TO DOWNLOAD THE DRIVER FROM YOUR CAMERA WEBSITE TO YOUR COMPUTER. THREE, YOUR COMPUTER WON'T RECOGNIZE YOUR CAMERA WHEN YOU CONNECT IT TO YOUR COMPUTER? USUALLY, MOST NEWER COMPUTERS WILL RECOGNIZE MOST CAMERAS WHEN THEY ARE CONNECTED VIA USB, FIREWIRE, AND TURNED ON. IF THIS IS NOT HAPPENING, THEN I WOULD SAY YOU NEED TO FIND THE DRIVER FROM YOUR CAMERA WEBSITE AND DOWNLOAD IT. HOPE THIS HELPS YOU
go to the link below for the driver, you dont need software as you can explore the camera in my computer and copy then paste the photos, but windows may come up with picture viewer when you connect the cam up to the pc
