SOURCE: Olympus Stylus 770SW error message
After only 15 days mine did the same thing. I called the dealer Olympus and they gave me a RAN number and told me where to send it. I got a call about a week later. They said because the camera had moisture inside I was not coverd. The best they would do is mail me a rebate card for 25 dollars off my next purchase. I was like WTF. The woman said sorry but that was all they could do. When I asked to speak to manager she hung up.
SOURCE: Olympus Mju mini - lens
check out first if the battery is fully charged.and if the battery is very old.then prefer replacing the battery instead of charging.and if the battery is new,then the cover of the lens must be getting stuck up so try tapping the device from all the sides it will automatically get opened.also off the camera completely and try to move the lens door manually up and down.sometimes the gear assembly gets stucked and this makes it free to move.
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
