Press the Menu or
Menu/Set key. Then
Fax,
Miscellaneous and Compatibility.
Press the Up or Down key until you can
select Basic. Basic reduces the
modem speed to 9600 bps.
Press OK or
Menu/Set or Set key.
Press Stop/Exit.
Note these instructions should work for the
following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C,
Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C,
MFC-3340c, and most other MFC models.
Honestly, Magic Jack will only mess your computer up more then it's worth in savings.
If you really want to leave the phone company, check out OOMA (ooma.com) it cost more in the begining, but saves WAY more in the long run.
Of the 10 computers I tried to fix after Magic Jack had been installed on them, I had to reinstall the Operating System on all of them. Magic Jack is worthless.
The baud rate or communication speed of the Brother 4100 Fax is not selectible by the user. It is factory set to begin at 14.4 (the highest speed) and fall back in increments until reliable communication is established.
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
Enter the parameter ____ on the key board and press the Check Mark.
159 - Receiving Fax baud rate
153 - Transmitting Fax baud rate
The screen will read Cfg param val: 26
Enter in the value ____ and then press the Check Mark .
0 = V.17 14400
2 = V.17 9600
6 = V.29 9600
10 = V.27 2400
Screen will read Test -001+
Press the Reset button until you get back to Ready
