SOURCE: Just bought a cruz reader
Before you can communicate with your computer you must run CruzSync from the desktop. There are some driver files that must be sent from cruz to point the way to the reader. After you do this it should connect every time. Some time you will have to pull the USB out and put it back end, especially if the reader or the computer has just woke up from a sleep or hibernation mode. ZumoDrive is the account you must set up when you click or press on CruzSync to make all of this happen. Hope this helps
SOURCE: I forgot the pattern to unlock my Cruz reader
Hi, enter wrong pattern few times and then it will ask you for your google account password :)
SOURCE: How do you restor you
The easiest way to restore the Cruz Reader to factory defaults is to update to the newest firmware which can be downloaded from here. The instructions for doing the upgrade are also explained on the link above.
This will revert everything back to original condition leaving any information on the internal and external memory cards intact. If you are looking to clear those as well you can do so by formatting the cards by going to Settings->Storage (might say SD card)->Unmount->Format. You can also take the cards out and put them in your computer and use the computer to format them.
The process is pretty of upgrading the firmware is pretty simple even though it might be intimidating. Let me know if you have any more questions
Hope this helps
Ray
forgot pattern lock password
I got a Proscan tablet PLT777G-Q for Christmas and I forgot the password ( Not pattern ) How do I factory reset it?
How to reset it back to factory settings? I forgot the password ( Not pattern )
i turn it off to charge.and when i tried to put my security pattern,back on,it will not accept.screen go"s on clock works.
Forgot pattern lock how can I hard reset to factory or bypass paternal lock on Emerson tablet model em543
I have tried putting my pin password in my tablet bit it wont unlock it and i have tried to many times
My RCA 7" 4MG tablet will not allow
entry. I possibly set voice password without realizing it. How do I get a factory reset myself?
my son has attempted to unlock is tablet but forgot his password and the tablet has now shut down. i would like to do a factory reset but not sure how
His password was a pattern where you connect the dots
how do i factory reset
tablet 8 forgot security pattern ,wifi is turned off when email and password are typed in it does not accept password
forgot password for irola tablet
screen is locked forgot password so just nee to factory reset
I got locked out of my nextbook next8p12 cause of forgotten password. I tried the power+volume up factory reset, but it just turns it off. it doesn't actually reset the tablet. what am I doing wrong?
Someone reset my password and now i cannot access my tablet. The factory reset button also is not working.
Can't get pass the start up password 9 year old was playing with it and somehow changed it.. Mow it just a paper weight
We set a password but have forgotten it. How do we reset the password?
use this toolhttp://www.firmware1.com/2015/12/android...
