How to transfer all contacts from phone to new SIM card
1. From the standby screen (the first screen when you open your phone), go to the menu.
2. Scroll to the address book and press select.
3. Scroll to the address you wish to copy (or any address if you want to copy all of them) and press the menu key.
4. Go down to copy and press select.
5. Select "Entries" to copy just that one entry or "All to SIM" if you
want to copy all your addresses to your SIM card, or "All to Phone" if
you want to copy them all to your phone.
6. Select Merge or
Override. Merge will combine any addresses that are already on your
card with the ones you are now copying, Override will replace anything
that is already there with the ones you are now copying. Be careful in
deciding which you want to do since Override will delete anything
previously saved and merge will duplicate any that were already saved
and are being saved again.
Depends what phone you have. generally copy all you contacts to your phone then put new sim in and copy/backup back to new sim from phone
SOURCE: tranfering contacts between different sim cards & cell providers
Im afraid you cant do that by transfering ur Fido SIM to Rogers ( since d fone is locked on Rogers Network) one thing i could suggest is use d Bluetooth ( worked perfectly fine for me) Good Luck :)
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
SOURCE: I have a Nokia E71 and using SIM from my old
open "address book", then press "option"scroll down to "SIM contacts" and press the right-navigation key and select "SIM Directory"
It will display contacts on your SIM card. To copy contacts from SIM to phone memory. Select "Options" then scroll down to "Mark/Unmark" press right-navigation key and select "Mark All" then select "Options" again and then select "Copy to Contacts"
That will copy your contacts from SIM to Phone directory.
Think its impossible to do on this phone aye. it has copy all to phone from sim but no option to do it back the other way...pretty annoying as im facing haveing to manually copy out all 100+ contacts. did any1 have any breakthroughs?
Samsung SPH-a660 Cellular Phone-unable to transfer contacts list
