Sounds like there might be dust inside of the laptop that is blocking one of the air vents. Plus the connectors to the screen may need to be reseated so that way the screen can be moved freely without it locking up on you and cutting off.
You have two issues going on. Bring it to somebody so they can open it up and make sure the air vents are cleaned out. Also they need to make sure the CPU fan is running properly. Then with the screen the connectors need to be reseated. Its also quite possible the screen connector might need to be replaced.
If the laptop is under warranty see if Toshiba will reapir it.
