How to uppdate from Windows Xp into Windows7 I have Motherbord MSI C31TM-P21
These are certain minimum required specifications that need to be met before you can upgrade Windows XP on your system to Windows 7. The memory requirement for upgrading to Windows 7 is 1GB RAM for the 32-bit version and 2GB RAM for the 64-bit version. Your processor should be 1 GHz or better, i.e. 32-bit x86 or 64-bit x64 processor. A 21GB disk space for the 64-bit version and a 17GB disk space for the 32-bit version are also required. A DirectX 9 supporting graphics card with a WDDM 1.1 driver is also necessary for upgrading to Windows 7. Make sure that your other devices are also Windows 7 compatible. get more information for Upgrading Windows 7 hope this helps you.
Well, it depends on your computer specification because every operating system has it own hardware requirements. Before upgrading to windows 7 make it sure your motherboard support the windows 7 operating system. In your case your motherboard supported by the windows 7 so when upgrading rather formatting your computer you must have the windows 7 installer. Then follow this video tutorial on how to setup your computer to windows 7. Before formatting you must have to back up all your data or files saved on your hard drive. Have a nice day
You can directly upgrade from windows xp to windows 7 by purchasing a genuine product key from; http://www.cdekey.com/, the key in this site is really cheap, you can go to get one.
Visit the link below:
Upgrading from Windows XP to Windows 7
