Vehicle Historyhttps://www.vehiclehistory.com > questions > where-is...
Located on the right side of the transmission near the output shaft. Like. (1). Leave your answer. 2 answers · Top answer: The 2007 Ford Focus speed sensor is found by watching: https://www.Youtube.com/watch?v=jxqItE9OI20 You will come into many issues with an engine. A gasket ...
Follow the upper rad hose to the thermostat housing. It will be there. There are two, one is the ECT (engine coolant temperature SENSOR) and the other is the temperature SENDING UNIT (input for temp. gauge ONLY).
to make you clear where does the oxygen sensors where is........... some have four, three or two, all O2 SENSORS ARE LOCATED AT EXHAUST PIPE. before and after catalytic converter,
if the throttle postion sensor is reading closed you will have to replace the sensor check for power and ground at the sensor there should also be a 5volt refrence signal sent from the pcm......the coolant temp senor is located (looking under the hood) on the right side driver side next to the end of the upper hose
its screwed into the cylinder head ,when you fit a new 1 dont overtighten it they sense temp of the head they dont screw into the water jacket!!!!!!!!!!!!!!!!!!!!
