Kyocera Mita KM-5035 Printer Logo
Posted on May 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KM 5035 cuts off top of copy image. Text is moved higher on page on copy vs original which cuts off the top of text on copy. Can't seem to figure out how to make it stop doing that. Happens the same using platen or feeder.
Anonymous
Level 3:
Guru:
  • Master 352 Answers
  • Posted on May 27, 2011
Anonymous
Master
Level 3:
Guru:
Answers
352
Questions
0
Helped
98127
Points
1095
Hello. Sometimes this can be caused by the duplexing mode being switched on. check the duplexing settings to rectify. Also if the paper position sensor is damaged this error can occur. this required a technician to replace.
I hope this helps Regards GM
Cut and paste
Learning how to cut and paste can make your life on the computer much easier.
It saves time and is more accurate that retyping the information, particularly if you do it several times.
If you know how to highlight words on your computer, you can easily copy sections of text and paste them somewhere else.
Open a text document or an email that contains some type.
Click at the end of the block of text you located in Step 1 and drag with your mouse back to the beginning of the text to highlight the entire block of type you wish to copy.
Release the mouse. The selected area should be highlighted in a color, usually blue.
Right-click the mouse on the highlighted text and a drop-down menu appears.
Select "Cut" to copy the highlighted text and remove it from its original position.
Select "Copy" to copy the highlighted text and leave it in its original position.
Paste the text you copied.
Right-click in an editable text box and select "Paste" from the drop-down menu.
The text appears in its new location.
Alternatively, highlight the text and hold down the "Ctrl" key on your keyboard while you press the "X" key to cut the text or the "C" key to copy the text.
These keyboard shortcuts copy the text that is highlighted.
To paste it, click in a text box and use the "Ctrl" and "V" shortcut to paste.
Cut and Paste Techniques in Microsoft Word
http://www.homeandlearn.co.uk/mw/s3p2.html
Cut and paste
Facebook allows users to connect with family, coworkers and friends new and old.
Users can send messages to friends, post events, share status updates and comment on friends' walls.
The built-in copy-and-paste function of Windows computers also works on Facebook.
Members of the site can copy favorite or important text and paste it into their profile page or on a friend's profile page.
Log in to your account at Facebook.com.
Click and highlight the text you wish to copy.
Press the "Ctrl" and "C" keys simultaneously to copy the text.
Click inside the area you wish to paste the text.
Press the "Ctrl" and "V" keys simultaneously to paste the text.
Hold the mouse down on text then drag along text to Highlight the text you want to copy and paste to your Facebook status with your mouse.
Right click your mouse on Highlighted text you should see option to cut as well as many other options.
When I cut and paste in microsoft word, the copy has a variety of differences from original, why?
Does this help
The text that you move or copy can have a font or other kind of formatting applied to it, such as bold or italic, that differs from the document where you are pasting the text. For example, you can move or copy text that is bold, 10-point Times New Roman, and paste it next to text that is regular, 11-point Calibri. If you want the pasted text to be in Times New Roman instead of Calibri, you can preserve its look.
  1. Select the text that you want to move or copy, and then press CTRL+X to move the text, or press CTRL+C to copy the text.
  2. Click where you want to paste the text, and then press CTRL+V.
  3. Click Paste Options za010181056.gif, which appears after you paste the text.
Printing too close to top page
In printer option select "Fit To Page"
3helpful
2answers
C7400 error kyocera km 5035
Error C7400 on Kyocera km 5035 is Image formation unit problem or connector
Hope this will help
How can I paste text using just keyboard (if paste icon does not work)?
Highlight the text you want by holding down the left mouse button and dragging across until you reach the end of your selection. Then press CTRL-C to copy the selection to the clipboard and leave the text in place, or CTRL-X to copy the selected text to the clipboard and remove it (cut it) from the document. Copying is handy if you want to duplicate the text somewhere, and cutting is for when you want to move it to some other place. Once you've copied or cut text to the clipboard, put the cursor where you want to paste it and press CTRL-V. This will insert the text from the clipboard at that location. The text is still on the clipboard, so you can move the cursor and CTRL-V to paste it in other places as well.
3answers
I want to scan text from a page.help me
Actually, there is an OCR tool that can help to scan the image and convert to text form which is Bitwar Text Scanner. It utilizes the Text Recognition and allows users to copy text from a screenshot or photo to word easily.
So first, all you need is to take a picture of the page and then continue with the steps below to copy text from image easily.
How to Copy Text from Image with OCR Text Scanner
Not many users know that OCR is a very reliable and useful tool that can help users when it comes to extracting word from a screenshot.
Step 1: Open the Screenshot file and Bitwar Text Scanner at the same time.
Step 2: Choose Screenshot OCR tool and Draw the textbox to capture the text from the screenshot image.
Step 3: After finish drawing the textbox, the OCR tool will Convert the screenshot to text format.
Step 4: Choose Copy to extract the text or Compare to compare the OCR results with the screenshot.
Start OCR Now!
OCR Text Scanner is an essential tool in our daily life as many industries are using OCR technology to enhance their industry efficiency. Besides, Bitwar Text Scanner also supports many operating systems such as Windows, iOS, and Android.
4helpful
2answers
We have a Kyocera 5035 Copier and getting a message "Page tray is out of order"?? Any ideas on what to do?
if you go into copy mode punch in 1087 1087
press the green start button
punch in 906
press the green button
select the option on the touch screen
and wait until the machine reboots
this should fix any minor problems
Text moves down the page when I copy - how can I stop this?
Sounds like it is either resizing the image or not seeing all of the original.
Specify the original size and do not use auto.
Make sure thsat image shift or image centring is not on.
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
