Question about Yamaha PSR-S700 ARRANGER WORKSTATION Keyboards/Midi
I'VE A YAMAHA PSR S700. The problem is with it's screen. Whenever i start playing, the screen fades and then it comes and it goes and vice versa. This occurs almost two - three days a week. There is no sound problem. What should i do?
  • stevedon781 Jun 21, 2011
    Is it necessary to repair the backlight problem?
  • Yamaha Master
  • 5,603 Answers
Likely a connection to the backlight is being broken. Tap on the unoit and see if it pops back on. Illuminate screen with a flashlight and see if the characters can be seen when screen is faded. If they can, then the backlight is the problem... IF NOT then the display may be bad... This has been a problem and if you are under warranty, excersise it immediately... else replacement of the display is relatively expensive.
Posted on May 28, 2011
Testimonial: "THANK U VERY MUCH.......!"
  • 2 more comments
  • stevedon781 May 29, 2011
    YES.... THANK U VERY MUCH. IT IS A BACKLIGHT PROBLEM. THE CHARACTERS CAN BE SEEN WHEN A TORCH IS ILLUMINATED ON THE SCREEN.
  • Fred Yearian May 30, 2011
    It may be that the cable powering the backlight has come partially loose and the vibration makes it come and go. When opening the unit, be careful of the ribbon cables connecting between the two halves of the case.
  • Fred Yearian Jun 21, 2011
    There is no danger of damage with the backlight like this, but it would sure be annoying. Try tapping the unit when it has faded and see if it re-connects... gentle tapping, not with a hammer or fist... do it with a knuckle for instance.
Am Kwofie from Accra Ghana:
I recently bought a Yamaha PSR S700 keyboard and it stated developing problem. Anytime time i switch it on the power comes and go off and on leaven the screen light on in the fade mode without seeing anything on the screen nor hearing sound unless you switch it off and on it again, and when it comes immediately you start playing it will do the same thing, the power adapter too is good so what may be the cause thanks?.
Posted on Jul 07, 2012
6ya staff
SOURCE:
How do you replace a failed LCD backlight lamp on a Yamaha PSR-S700 keyboard? Is this a user or a workshop repair?
The backlight is not shown as a replaceable item only as part of the LCD unit. There is a complication in replacing the screen as the original screen is no longer available and a replacement screen also now involves other modifications beyond the average user I would suggest.
Speak to your local Yamaha dealer for a price on the screen kit
Oct 16, 2016 | Yamaha Music
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
Sep 15, 2016 | Yamaha Music
Yamaha psr700 speaker cover removal
Assuming this is a PSR-S700 then you need to undo all the screws under the keyboard and open up so you can see inside under the speaker grill. You will see the grill has tabs that poke through the casing and these are then twisted to keep it in place. Straighten these, push tab through casing going from side to side and then the grill will eventually work free. You do not want to do this too much as the tabs will eventually break with wear.
Jun 18, 2016 | Yamaha PSR-S500 Digital Keyboard
Psr s700 display has been changed colour blue then display is blinking what is the problem
change the whole screen the on capacitor 344 & 544 add resistor with value 2.2k, it will help your keyboard stay longer.
Aug 07, 2014 | Yamaha PSR-S700 ARRANGER WORKSTATION...
Yamaha PSR-S700 reset
Press the last note (right side) while powering your s700 ,this will reset your settings.
Jul 04, 2014 | Yamaha PSR-S700 ARRANGER WORKSTATION...
My psrs 700 the back light its off i need to know ?where may i buy it !!!
Well first start by calling or emailing the manufacturer. They'll let you know who distributes their parts or If it's still available or not. But also could be a power supply problem.
Oct 01, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
I have a Yamaha PSR S700 keyboard. Whenever I play it, the OTS settings automatically gets changed and disabling all my other buttons on panel. Only if I select 'No' for the question displayed in...
It sounds like one of the OTS buttons is getting triggered accidentally. There may be a build up of residue behind the button. With the unit off, try rapidly pressing the OTS buttons, one at a time. This should help to move any debris which may be creating a false contact.
If you are feeling brave, you can try opening the keyboard and getting inside, under the button with some electrical contact cleaner such as DeOxit or Servisol.But be warned: it can be difficult to get the parts back together properly! So if you don't have much servicing experience, call your local music shop to find a service technician.
Sep 19, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
This morning during a church performance, 1/2 of our display went out on my PSR-S500. Is this a user-replacable part? I'm pretty handy with a meter and not afraid to crack the case. This item is not...
It is shop replaceable. I have heard this is NOT an uncommon problem. You can get the parts through Yamaha America in California. Here is your service manual:
http://elektrotanya.com/yamaha_psr-s500.pdf/download.html
Scroll down to "Get Manual" and click on it to download the manual (about 12Mb)
Yamaha support/parts contact
http://usa.yamaha.com/support/
May 15, 2011 | Yamaha PSR-S500 Digital Keyboard
The keyboard is showing sign of power input but the screen is not lighting and produces no sound
1. Try the volume
2. Your adapter may not be the proper voltage/amperage. If the adapter has ratings listed, make sure they match the keyboards ratings.
3. Try it with the headphones. If they work and the speakers don't, you've narrowed down your problem. There may be some damage or wiring problem within where the board meets the speakers, and/or before processing.
4. Try it with batteries. If that works, you need a new adapter.
http://www.ioffer.com/i/adaptor-cord-yamaha-psr-or700-s500-s700-s900-arranger-113553507
Feb 06, 2011 | Yamaha PSR-S500 Digital Keyboard
Yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Jul 22, 2010 | Yamaha Full-Size Keyboard
Yamaha PSR-S700 ARRANGER WORKSTATION Keyboards/Midi Logo
1,179 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
