SOURCE: LG front Loader Intellowasher 7kg WD-8015c has
If this has a mechanical timer, the clock drive gears may have a damaged tooth or a piece of debris is blocking further turning of the dial. If electronic, the control unit should be replaced.
SOURCE: hello. I have an LG intellowasher front loader
If you've waited the normal time for the interlock to allow the door to open and it's still locked, the interlock switch itself is probably faulty. Tricky job. Best to find a repair technician........Nomess
SOURCE: Manual for LG Intellowasher 7kg
While not exact to your model,this manual may answer your questions.
http://136.166.4.200/contents/Laundry/WD-1070FH/WD-1070FD_Service_Manual.pdf
SOURCE: i have a lg intellowasher 7kg wd-8015c (front
the water pump is sending a signal to the pcb telling it there is a fault clean the filters and wheel on the water pump
let me know how you went
sonic boom electronics
