Expert
- Posted on May 29, 2011
Re: I got an Audi TT Turbo Model 2000 The radio Bose Audi...
- Turn on radio. The radio display shows "SAFE".
- Press the FM2 and RDS buttons simultaneously and hold until
"1000" shows on the display. Release the buttons. Do NOT
press these buttons again, otherwise the radio will consider "1000"
to be the code.
- Use Preset buttons 1 ... 4 to enter the four-digit code number
from your radio card. Preset button 1 corresponds to the first digit,
Preset button 2 corresponds to the second digit, etc. Each press of
the button increments the number by 1.
- Once the code shown on the display is correct, press the FM2 and RDS
buttons simultaneously and hold until the word "SAFE" appears in the
display, then release the buttons.
- The radio should unlock and be usable shortly afterwards.
- If an incorrect code is entered, the word "SAFE" appears, first flashing
and then continuously. You can repeat the above steps to unlock the
radio once more, the number of attempts will be shown in the display.
If an incorrect code is entered again, you radio will be locked for about
one hour. After one hour - the radio must stay on and the key must remain
in the ignition lock - if the display goes out, the you can repeat the
above procedure to unlock again. The cycle - two attempts, one hour
lock-up - still applies.
