This pictorial guide will help me explain,
http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M55/laptop_motherboard_1.htm
ALL power removed from the laptop. Remove the AC adapter (Charger) and Battery.
Follow Anti-Static Precautions.
Place a towel, or suitable object on a table, then turn the laptop over, and place on the towel.
If you click on the photo in Step 2 you will see the Harddrive Compartment Cover.
Remove the Philips head screw.
Lift up on the side of the Harddrive Compartment Cover where the screw was.
Remove the cover, lay it aside.
The harddrive plugs into an interface in the Harddrive Compartment.
On the opposite end of the harddrive where it plugs into the interface, should be a single Philips head screw.
Remove the screw.
Use the fabric cloth to gently pull the harddrive away from the interface.
The harddrive may come back only so far, then the end is lifted up to remove the harddrive.
(End opposite of the back of the harddrive where it plugs into the interface)
Use caution as you can accidentally bend pins on the harddrive.
For additional questions, or to clarify what I have stated please post in a Comment.
Regards,
joecoolvette
