Hello &
Welcome to FixYa
F2 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
