Sony Bravia KDL-32ML130 32 in. LCD TV Logo
Posted on May 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony Bravia KDL-32ML130. I turn on the tv and the colors are really red and the pictures seems like it's moving in slow motion. It does this with the Direct tv, dvds, and vhs. The sound is fine. The picture looks clear, at times, when there is a still picture on. What is the best way to solve this problem?
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on May 30, 2011
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957518
Points
33084
LCD Panel (screen) is defective and need to be replaced to solve this problem.
Click YouTube.com to watch similar problem in lcd tv that brought to my repair shop.
Thanks.
I have Sony LCD 32 inch BX-300 model. The picture is appearing double and jerking in up & down motion. It seems that the top portion of 2" on the LCD is working fine and the remaining portion is...
it is hard to be sure what the issue is but are you sure it is not the cable or hdmi connection are you using an air antenna or actual cable or satellite signal this issue sounds like a non cable service issue meaning you have an air antenna hooked up is this true?
2answers
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
4helpful
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Hortizontal bars at start up and blurred motion
call sony unit has bad lcd panel may ave extended warranty
3helpful
2answers
Sony Bravia 32'' picture problem - Sony KDL-32ML130
I am having same problem, started today, didnt find any solution to this question on forums :(
2helpful
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
