Try this steps , hope it will help you:
Unlocking:
If you have Rev 1.5 (x426) or earlier and most older models
Use the *#9998*3323# Trick (look for it on the forum)
The *#1111*WHATEVER# code will NOT work
If you have Rev 1.6 (x426) or later and most newer models
You MUST use unlocking software. Codes WILL lock your phone FOREVER
Locked: Return for Servicing
There is only 1 working solution, you must flash a copy of the firmware
that is not in the locked status. (Most) Unlocking programs will NOT
disable this issue, and your service provider cannot give you a code
If you do not plan to use your phone with another service provider,
there is no real point to unlocking your phone other than to sell it.
If you don't need to unlock it, don't take the risk of disabling the
phone altogether
The *#9998*3323# Method:
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
2. Put a SIM card that is from a network other than the one your phone is locked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This
will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000)
10. Completed. You have now unlocked your phone.
Thank you for using fixya..
Please rate me on fixya and provide testimonial if ever to continue my further assistance..
Hi my name is ELIKE Can u unlock my nokia6303c FOR ME PLEASE. I don't know what is the restriction code. This is the IMEI is 359333/03/881321/0 .this is my email address [email protected]@yahoo.com please send me code.
thanks!
