Where in the cycle is the machine stopping?
A 1E error would be a fill problem. Either the water supply is inadequate (low pressure coming in due to a problem with your water supply), the water supply taps aren't fully open (make sure to open the valves fully), the inlet hose is bent (straighten the hose) or the inlet filter is clogged (clean the filter).
An UE error happens during the spin cycle. Either the load is too small or the load is uneven. Add some items that can tolerate the spin cycle speed or redistribute the load.
A LE error indicates that the motor has overloaded. Wait 30 minutes and then try to restart the machine. If the error persists, the unit needs service.
The manual for the WM-2277H* is available from LG as a DjVu file here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=WM2277HB&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WM2277HB&initialTab=documents&targetPage=support-product-profile# .
I hope this helps.
SOURCE: Error message UE is displayed and the machine has
UE means unbalanced load. This happens when the load is too small, or the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
