If you are using an HDMI cable that is all you need, HDMI is capable of transmitting video and audio to your TV. So the only thing to do now is to get your tv to switch to the DVD player from its normal TV signal. On your TV's remote control you should see a button called 'input' pressing this will bring up a menu of all the possible forms of input on your tv, most modern tvs will have at least 3-4, there may even be several HDMI inputs, the one you need should be labeled on the back of the tv or wherever you plugged it in, but the easiest way to figure out which it is, is to start a dvd playing, then cycle through the available inputs by pressing the input button on your tv's remote repeatedly until you see the picture on screen. (give each a few seconds before switching to the next, as some tv's do have a slight delay before displaying the image).Then make a note of which of the HDMI ports it is for future use.
Hope this was helpful.
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
