Canon MP280 All-In-One InkJet Printer Logo
Posted on May 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have a canon PIXMA MP280, I tried to scan a document today and the scanner will not operate and no alarms are activated on the printer. I have shut down both the computer and printer disconnected then reconnected all components and replaced the low ink cartridges but the screen still continues to flash but do nothing when i press the scan button
orlandoc_dos
Level 2:
New Friend:
  • Expert 125 Answers
  • Posted on May 31, 2011
orlandoc_dos
Expert
Level 2:
New Friend:
Answers
125
Questions
Helped
26386
Points
374
Try to scan tru your pc not in the printer if its work then maybe you have a dirty contacts on your scan key in the printer
How can I remove rear panel to clean out paper drive?
PDF]Canon MP280 series On-screen Manual
content.etilize.com/User-Manual/1017865665.pdf
See Operation Panel. .... Lights or flashes orange when an error occurs, such as paper-out or ink-out. .... You can switch the size of paper loaded in the Rear Tray between A4 and 8.5" .... Remove the original on the Platen Glass after scanning is completed...... For details on the printer driver settings, see Printing Documents.
I cant connect to my laptop need a software
this is the link for what you need, you only hae to choose your operating system. Canon Support Drivers PIXMA MP280
Good luck
Canon pixma MP280 error31
hi, error31 and others can be cleared by holding the reset button down until it sounds like it wants to print- push scan and start
should be no error and work fine you have to hear the printer work after reset is pressed or you reset again until it works hold button for ten to fifteen seconds 10-15
5helpful
3answers
I have pixma MP145. i want use my scanner corectly
you have to install the scanner driver & application in able to use the scanner to scan documents.
here is the driver for your scanner, download & install it.
Canon PIXMA MP145 Printer Driver 1.05 For Windows Vista(32/64)/XP
1helpful
Scanner crops documents
Go to the official Canon website: www.usa.canon.com and redownload driver and MP Navigator. MP Navigator lets you choose the size of the scan you want. I was having the same problem and just fixed it today.
Scanner doesn't scan or transmit document to pc
My printer does the same. And it's my third Canon printer and ever time when I try to scan a picture or etc. it just ends up saying that the printer can't communicate or that it's shut off. :(
old marine
old marine
ZJ Limited
ZJ Limited
