Accuracy is not adjustable with the screw on the side of the gun, that screw would be the velocity screw and should not be played with unless chronographing the gun to avoid setting it at unsafe velocities.
If you'd like better accuracy there are 2 upgrades you can make. #1 is higher grade paint. The more round and smooth the balls are, the more consistent and tighter the grouping will be. #2 is barrel. The closer the bore matches the paint, the more consistent and tighter the grouping will be also.
