If you are a mobile repair technician, please refer to this TUTORIAL, But if you are not a mobile repair technician, you better take it to a repair shop and get it repaired, otherwise you will not be able to understand. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
First Option:
You Go to Phone Setting in ringtone setting and check the Ring tone Setting If Ring tone Setting Ok But Not Ringe tone So
Secne Option:
Your Phone Ringer Default So Please change Ringer
And Ringing Problem will Solved Quickly
menu 2 settings 3 tones incoming call alert (set to ringing) ringing tone ( pick your ring tone) ringing volume (set to level 5 loudest) vibrating alert (on) message alert tone (pick tone) instant message alert tone (standard) keypad tones (on) warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok alert for (all calls)
You need to changed u r phone ringer, but somtimes it start by some claning, open ur mobile cover & clean the speaker area with the help of tooth brush gently,if it doesnt work change ringer
there is problem in the circuit of ur phone. the track of ringer may be damaged better u take it technician so can be checked properly, 99% problem will be with tracks. tracks is opened. take it to technician
Check user customizable profile. Whether it is set Vibrator mode in General mode. Even by key press mistake it might happens. Check profiles section. if you feel Risky Contact authorised mobile service stations. thank you !
