I ride a Trek 6.9 and have had spokes break for no apparent reason. Most of the time the spoke will break from over tightening on initial installation or just plain fatigue. Replacing the spoke is fairly straight forward. Remove the wheel from the bike and remove the tire. Remove the protective tape on the inside of the wheel to gain access to the spoke nut. After replacing the spoke you must make sure the wheel is true. If you do not have a set up for this, reassemble the wheel with the new spoke and take the assembly to your nearest bike store. They should have the equipment to true up your wheel assembly
Testimonial: "Thanks for the sensible advice - will get it sorted"
Email post in box
