Error 520 in Ricoh machines mean the main motor is blocked. Someone posted an answer here saying its caused by the blocked fusing unit. This is ONLY one possible cause. I got that problem a week ago, in a MP2001SP. I though it was the fusion but the unit was OK! It was a stuck gear inside developing unit (PCU). Sometimes , the foam joints inside that unit get flat, allowing some developer and toner infiltrate in the driving gears compartment,damaging them.Redoing the joints an replace the gear kit will solve the problem. I hope i helped someone with this post.Error 520 in Ricoh machines mean the main motor is blocked. Someone posted an answer here saying its caused by the blocked fusing unit. This is ONLY one possible cause. I got that problem a week ago, in a MP2001SP. I though it was the fusion but the unit was OK! It was a stuck gear inside developing unit (PCU). Sometimes , the foam joints inside that unit get flat, allowing some developer and toner infiltrate in the driving gears compartment,damaging them.Redoing the joints an replace the gear kit will solve the problem. I hope i helped someone with this post.
You can't post conmments that contain an email address.
Tienes problemas con el disco duro de la copiadora, puedes formatearlo haber si se restablece, para eso tienes que:
1.- prender la copiadora presionando 0+8
2.- poner 690 y presionar start
3.- poner 2 y presionar set.
4.- esperar el mensaje en pantalla de reboot the machine, puede tardar hasta 5 minutos despues de ahi tu disco esta dañado y necesita reemplasarse, junto con el firmware.
5.- apaga la copiadora y vuelvela a prender.
¿Usted tiene el poder pero su copiadora no trabaja? ¿Esto es una copiadora o una impresora? Por favor dígame la marca registrada de la copiadora y el número modelo. Gracias.
ERROR 502 Y 501 EN UNA COPIADORA AFICIO MOD 3035
