Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Posted on May 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yellow tint picture is yellow in middle - Panasonic PT-50LC13 50" Rear Projection HDTV
Mando Mojica
Level 3:
  • Master 643 Answers
  • Posted on May 31, 2011
Mando Mojica
Master
Level 3:
Answers
643
Questions
0
Helped
299026
Points
1928
That indicates your color wheel or optical block is bad. Repairs are usually pretty costly. Around 1100 to 1300 dollars. Hope this helps.
Picture has a blue blob-like on side and bottom. Also has a yellow shade in middle when viewed from 15 ft +?
Jerry to be frank with you I would not invest another cent in that Tv. The new once are getting cheaper and you would be alot happier. If you do decide to purchase a new TV look for SMART TV'S. Good Luck.
I am noticing a yellow tinted circle in the middle of my screen. It is noticible when the screen is blank between channels and you can see anything white on the middle of the screen is tinted yellow. Do...
Is it an LCD tv or CRT ?
If CRT try moving the TV to a different location as the magnetic field from another device or even the earth can effect it.
The power switch (full power on) would normally demagnetise the screen.
If its an LCD has any object hit the screen, it could be a child's toy or knocking the screen can bruise the panel.
Have a yellow tint in the middle of the screen
i have a yellow cricle on the middle of my screen how do i fix it
Hi I have a Hitachi 50v720 and I just replaced the bulb with the Phillips UX21517 bulb. When I turned the tv back on the picture worked fine except everything has a yellow tint.
I don't know if this set is a DLP or not, if it is, it could be your light engine. Not good, mine had a yellow halo about 2in thick in the middle of the screen. Light engine had to be replaced. Hope this is helpful. GOOD LUCK!
1helpful
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
1helpful
We have a yellow tint in the picture, it is worse
Yes, It could be either your video board or your dmd board, go to the service menu and if the yellow tint is still there, it's your dmd board, if not it will be your video board
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
2helpful
2answers
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
