SOURCE: el lcd lg w1934s solamente prende por 3 segundos y
Son los inverters, tenes que cambiarlos, estan al frente del monitor, hay que sacar la tapa del frente y reemplazarlos.
SOURCE: Necesito saber si el monitor LG Flatron L1718S,
You manual is HERE
Testimonial: "Lamentablemente no puedo testimoniar al respecto, ya que no permite abrir el archivo: http://i.eggie.cl/14100.jpg"
SOURCE: Hi can my flatron L1718S monitor be connected to a
You will need another box to convert the output signal from Sky box to VGA output to feed the monitor. Juts Google ' Video to VGA adapter'. For example:
http://www.thenerds.net/STARTECHCOM.StarTechcom_Composite_and_S_Video_to_VGA_Video_Converter.COMP2VGA.html?affid=8&productads=1
You may also need a good set of powered speakers for good sound.
Please leave rating if it helps.
Testimonial: "Thanks for your help, most appreciated"
SOURCE: I have a LG Flatron
If the power light remains on after it goes black, the problem is the inverter board that powers the back light behind the screen, the cause is usually bad capacitors. To fix it, the board must be replaced or attempt made to repair the inverter board.
