hello....just had the same proble... u probably need to clean or fix the port... (if u try to pull out just a little bit the jack u can see that everything it works properly). I opened the snare (ccrew it out) , i cleaned the components with some spray and noweverything works.
Unplug all the other triggers and see if it is in the mechanics of the kick mechanism. If not, then one at a time plug in the other triggers till you find one that is causing it. Could even be the bass when amplified is triggerin lightly the rim of the snare for instance.
A weak snare is a characteristic of these... The triggers are typically piezo discs that were often used in musical cards but those have now gone to using very flat little speakers... You may find some have been dislodged or broken loose... worth a look inside.
Ibelieve I havefounda goodpart of the solutionto this problem.I alsohadthis problemin thesnare.The problem wasso severe that,whenpulled,thesnaresupport,without givinghimany beat,the soundappeared.I took courageand openedthesnare.Aoopen, I realizedthat ayellowadhesiveused toglue thetriggerwirehadmelted andthe othertouching thetrigger.I thinkthis musthave happenedat some pointprior to mypurchasethat equipmenthasbeen underexcessive heat andthendrainedto such aglue.Simplycutthe littlewireglue"connected" twotriggers,andclosedthesnare.......ready:is working perfectly.
With this kit being acoustic-electric, the only advice I can give is to disconnect your snare trigger and mic the snare. It's either that, or your snare trigger is faulty. A new trigger is going to cost about the same as mics, but mics won't hit your snare, making you sound inexperienced. For miking the snare, you'll want to get two mics, placed on the top and bottom head. Try to position them on the same spot on the rim to avoid voicing problems. Studio drummers do the same thing when recording.
For playing this way live, you'll want to use either the main PA, or run to a separate mixer so you can control the volume of the snare in relation to the rest of the kit.
Your Xtalk filter is set too low. Refer to the owners manual for how to adjust individual triggers' sensitivity to "cross-talk" (vibrations carried from other pads)
My bet is you unplugged the crash trigger, but not the cable from the actual module (the brain). If you have a cable connected to the brain but not to a trigger, than any little bump to the end of the cable that isn't connected can be picked up as though you hit the pad normally. (play with the end of the cable a little, you'll see what I mean. It's kind of neat.)
Absolutely NOTHING is wrong. The snare drum resonates. The only solution is to NOT let th snare drum "hear" the Cajon... This is a common problem... Other instruments can also trigger the snares... SOME people add clearance of the snares to the drum to avoid some of the problem.
The polarity switch selects whether the pressure causes a positive or negative electrical spike. This can affect whether your drum MODULE fires on the hit or when the hit is lifted.
Thin plastic triggers are an electret plastic and have piezoelectric properties.when their shape is changed by pressure, etc.
this is an easy problem to fix. The piezo piece on the inside of your bass drum trigger uses a double sided tape that is fixed to a metal disc. the piezo trigger just fell off. mine did the same thing. I actually glued mine with epoxy and have not looked back.
