Connect some text-based terminal emulator such as Hyperterm, telnet,VT100, etc to the serial port. Configure the emilator
to19200 Baud 8 plus none.
Switch the 4924 on and login using the user "recover" (without quotes) and password "recover" (also without quotes.
The switch will go into recovery mode. It will display a count-down starting at 30 seconds. If you power thye switch off before the count is up, the default password for the main administration account "admin" will be cleared.
After a few seconds, power the switch on and set a new admin password.
After loigging in again, take the option "GettingStarted". Configure the ip settings (best to use a static address) and eventually you will get to the "Initialize" option. Enter yes, and after reboot it will be at factory except for its ip address.
