Hi Almostbob,
Our water sensor isn't working. I did some research and wanted to confirm that the 80 series is similar enough to the 90 series, that I can remove the console and check the water sensor settings. Any special hints about taking off the console and what, exactly, I'm looking for at the water sensor location? Thanks so much, this is my first try at home repair!
Hugs,
carole
Yes,
Kenmore is uniformly easy to work on, everything comes off from the front.
There are two 80 models,
on the most common, newer model, the edge trims on the console pop off, there is a phillips screw in each corner, remove the screw, slide the console forward, lift up and flip over.
on the older one the console is released by sliding a putty knife or other blunt blade under the corners of the console to uncatch a clip, lift up flip over
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test
The water level switch body contains a small spring that is not really up to the job and stretches over years,
do this repair, on call, no parts, takes 15 minutes,, 3-4 times a month
For guest
the second set of instructions deals with your problem, I think.
remove the knob and control body, then you can adjust water level with a very small (1/8inch) bolthead/nut next to the knob shaft
Our Kenmore 80 Series overflowed tonight, and it took less than 5 minutes to figure out the solution (based on this site). The pressure sensor tube came loose. I re-attached and it now works fine. THANK YOU!!!
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
This is a most amazing site...I utilized some previously posted info. to fix my washing machine and then AlmostBob came along with the rest of the story! Thanks so much!
carole
I followed the directions on removing the console. The tube seems to be attached properly, the dial stem will rotate properly. The water level will only fill half way. Is there another solution to this problem.
Hi Almost Bob, My Kenmore 80 Series recently started only filling to a small load level. I followed your instructions and there was water in the hose. Blew out the water with an air compressor and it raised the level an inch or two but still not up to the level of a large load. Also moved the bolt clockwise, moved the switch back and forth and can see that it's moving okay, but still not as high as it should. Any suggestions as to next steps? Also, if the water sensor itself needs to be replaced, how do I go about ordering that? Thanks for your help. BTW, this is my first venture into washer repair and I found it enjoyable, especially with your excellent instructions! Wendy in Connecticut.
