You will need the agitator repair kit to repair it, that knob at the top shaped part just unsnaps,
get a flathead screwdriver and pry it up and off. The knob part is #1 in
the next diagram link, then pull the cap with the handle#23 up and off,
then remove the bolt#2 then the upper part of the agitator will come off; check the diagram copy/paste this link in your browser...
Juts like a sample; here's the one for your model you can order -->> appliancepartspros.com/part_details.aspx?part_id=3138838&pn_=285811
Keep in mind that (generally) this kit comes with instructions and installation guide.
My splendide 1024m washer doesn't fill or seem to run. the only time it does anything is if the wash cycle selector is in the prewash position and the dryer is turned on.Then it spits water from the drain, and the drum rotates
