Hi There are a few things that could be wrong with your TV. Hopefully it's the T-con board or the signal board. The third thing is the screen could be bad. There is no way of telling without replacing the first two parts if that does not solve your problem then your screen is bad. I guessing if you are asking that it's out of warranty. I would start by replacing the T-con board. the T-con is the board that connects the screen to the signal board it is attached to theback of the screen in the top middle part. To replace parts you have to actually remove the part first to get the part number from it other wise you run the risk of ordering the wrong part. Also when changing the T-con try to change the ribbon cables that are connected from it to the screen. If the problem is still there then I would replace the signal board. again you would need a part number in order to get it. you can find parts at www.interliquidparts.com I hope this helps.
