SOURCE: continues to freeze
It sounds like the temp sensor isn't working properly and letting the compressor run all the time till it freezes. If you are "handy" you can replace the temp sensor. Parts are available online at different websites like repairclinic.com or partselect.com, etc.
SOURCE: Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
SOURCE: danby compact 482 fridge is
Hello tbrown7777
Welcome.
You said, Your Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Just 482 is incomplete!!!!!!!!!
Can you send me the complete model number off the sticker in the fridge or on the rear of the fridge?
and the year of it! waiting your response!
Huuum
SOURCE: Danby Ignis Refrigerator light isn't working
See this link and scroll down to see information about parts for a Danby refrigerator:
http://www.rekitchen.com/refrigerator/brands/danby.html
