Behringer XENYX 2442FX Mixer Logo
Posted on Jun 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Poca sensibilidad en los microfonos, el canal MAIN R no tiene audio
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Jun 04, 2011
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2250417
Points
16163
Set PAN knobs at 12 O'clock.
I have an EMX5016CF mixer. 2 of the channels have both the peak and signal lights permanently on. What does this mean?
Hi Safa Mashat, the problem with the two lights, can have several origins
First, disconnect the signal that enters these two channels and check if they are still on, but they are, the problem is in the cable or device that is connected to that line
If the fault still continues, it is most likely that the two-channel input stage has been damaged.
In this case if you have technical knowledge, I send you the service manual link
If not, I suggest you look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Safa Mashat, el problema que tenga las dos luces, puede tener varios origenes
Primero, desconecta la se?al que le entra a estos dos canales y verifica si siguen prendias, sino lo estan, el problema esta en el cable o aparato que esta conectad0o a esa linea
Si aun continua la falla, lo mas probable que se haya da?ado le etapa de entrada de los dos canales
En este caso si tienes conocimientos tecnicos , te envio el link del manual de servicio
Sino, te sugiero buscar un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/yamaha_emx5016cf_sm.pdf/download.html
https://mx.yamaha.com/files/download/other_assets/5/334285/emx5016cf_es_om_d0.pdf
Jul 21, 2019 • The Music
2answers
Behringer Europower PMP 1680S--The FX channels both Master and Monitor banks do not create any effects but instead only produce a rapid, repetitive clicking/popping noise. HELP!
Hello Geoff, try using an external processor and check that it works well, if so, the problem is that you have the Jack connectors of Effect sending and those of Return of Effects, dirty
Apply a couple of drops of oil, type WD40, to a Plug connector and insert and remove them repeatedly in each connector Jack for sending and returning effects
I hope you can solve the problem, comment the results
Hola Geoff, prueba usando un procesador externo y comprueba que funcione bien, si es asi, el problema es que tienes los conectores Jack de envio de Efecto y los de Retorno de Efectos, sucios
Aplicale en un conector Plug un par de gotas de aceite, tipo WD40 y entralos y sacalos repetidamente en cada conector Jack de envio y retorno de efectos
Espero puedas solucionar el problema, comenta los resultados
https://media.music-group.com/media/PLM/data/docs/P0A8M/PMP1680S_PMP980S_PMP960M_M_EN.pdf
https://c3.zzounds.com/media/PMP1680S_P0A8M_OI_EN_ES_FR-df44b2314272dfc61a7cabe5bb88ecce.pdf
1helpful
How do you open the fuse tray on a peavey 4b mixer to check on no power?
Hello John, the fuse is in the power input of Tu Peavey
If you notice, on the rear panel, where the power cord is plugged in, up on the same connector, you will see a horizontal cover that can be removed by placing a tip on the underside of this cover and pulling outwards, it will come out a plastic element, which holds the fuse, this element has an intermediate space where another spare fuse can be housed
I hope my comment has been useful and you can take out the fuse
Keep in mind that if you blow the fuse, because I pass, check the cables and speaker connectors, that do not have any short circuit
Hola John, el fusible se encuentra en la entrada de energ?a de Tu Peavey
Si te fijas, en el panel trasero, donde va enchufado el cable de corriente, arriba en el mismo conector, vas a ver una tapa horizontal que se puede sacar poniendo una punta del lado de abajo de esta tapa y haciendo fuerza hacia afuera, saldr? un elemento pl?stico, que sostiene al fusible, este elemento tiene un espacio intermedio donde se puede alojar otro fusible de repuesto
Espero que te haya servido mi comentario y puedas sacar el fusible
Ten en cuenta que si se quemo el fusible, porque paso,revisa los cables y los conectores de parlante, que no tengan ning?n cortocircuito
https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwiUpJWv4bDiAhUTIrkGHXfyDoQQjRx6BAgBEAU&url=https%3A%2F%2Fwww.tme.eu%2Fhtml%2FES%2Fconectores-machos-iec-con-proteccion-de-fusible-para-panel-schurter%2Framka_3250_ES_pelny.html&psig=AOvVaw3u39E87rodMysi11CwjaR6&ust=1558670267837577
My behringer eurodesk sx3242fx has a problem with the MAIN OUT XLR (L&R)....LEFT side is not working what is the problem?
Hi Ezra, for the failure you describe, you may have a problem with the Main Insert connectors, more presumably on the left, this connector has the function of interleaving some type of processor in the stages of the master L and R, and has some contacts internal that get dirty and produce false contact in the passage of the output signal
Try cleaning it with some contact cleaner, put a small amount of cleaner and with the help of a plug, put it on and take it out several times in order to make the cleaner work, do the same with the right channel, because the same fault will appear. , sometime
If this does not work, you would apparently have problems with the left master dimmer potentiometer on the corresponding electrical circuit
I sent you the link to download the user manual of your Behringer
I hope you serve my suggestions and manage to make the left exit work
Hola Ezra, por la falla que describes, puedes tener un problema en los conectores Main Insert , mas presisamente en el Izquierdo, este conector tiene la funcion de intercalar algun tipo de procesador en la etapas de los master L y R, y cuenta conunos contactos internos que se ensucian y producen falso contacto en el paso de la se?al de salida
Prueba limpiarlo con algun limpiador de contacto, pon poca cantidad de limpiador y con la ayuda de un plug ve colocandolo y sacandolo repetidas veces a los efectosn de que el limpiador actue, haz lo mismo con el canal derecho, porque ya le aparecera la misma falla, en algun momento
Si esto no da resultado, aparentemente tendrias problemas con el potenciometro atenuador master Izquierdo on el circuito electrico correspondiente
Te envio el link para que descargues el manual de usuario de tu Behringer
Espero te sirvan mis sugerencias y logres hacer funcionar la salida Izquierda
http://www.manualsbase.com/es/manual/downloadmanual/119881 https://manualsbrain.com/es/manuals/809021
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
I cant figure out how to connect my xenyx 1832 fx to my desk top computer
alcuni canali non funzionano metto il microfono e non va lo metto in un altro canale funziona come mai? salve e grazie gioago 1
3helpful
Como puedo conectar mi Consola Peavey de 32 Fx en mi mac OS X 10 y tengo instalado Pro Tools M-powered y pro tool HD necesito que me reconozca los 32 canales para poder grabar en multipista.
Necesitas los drivers que deber?an venirte en un cd con la consola. Si no instalas eso, la PC no reconoce los AD converters que usa cada canal , que ser?a como agregar la misma cantidad de tarjetas de sonido nuevas, y es imposible que puedas grabar.
Si no tenes el CD, deber?as ingresar en la pagina del fabricante para descargarlos.
2helpful
2answers
Lexicon Alpha got phantom?
The Lexicon Alpha does NOT have phantom power. The mic input expects a standard mic or a "self-powered" condensor mic. This means that you will neex external phantom power. There are power units available that use 9V batteries for this.
Dan
45helpful
8answers
My roland xp-50 keyboard is dead.
Ok guys. Just got mine XP50 fixed with the "No Display" problem. The LCD screen was blank without text and only shown orange color. The problem is one of the capacitors on the main board was dead. I have replaced all 3 caps on the main board and the problem is solved and if you are a little handy on soldering, you can do it yourself. The 3 caps you should replace are:
- C901 (I used 16V 330MicroF)
- C65 (I used 5V 4.7 MicroF)
- C 902 (I used 16V 330 MicroF)
Apr 07, 2009 • Music
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
