The first thing you should try is resetting the PRAM, this can be done by following this guide.
Then use the Finder to view your User/Library/Cookies/ folder, and drag the Cookies.plist file to the trash. now try Safari again.
If that cures the problem, then we know the cookies file was the reason.
Unfortunately you
may lose various website settings and passwords, that were stored in
the cookies.
If the problem still persists after this I would try calling apple support.
Before that you can re-install the latest version of Safari by downloading from www.apple.com, after removing it from application folder.
SOURCE: can i place a 4g and 2g stick in my macbook pro
Hello! The MacBook Pro you have mentioned can only support 4GB's total. 2GB's in the first slot, and 2GB's on the second slot.
What you may have seen by accident was that you can purchase either a 4GB kit, or a 2GB kit. Meaning a 4GB kit with 2 2GB sticks, or a 2GB kit with 2 1GB sticks.
Your best bet is to go with a 2GB stick in each slot to max out your MacBook Pro. 2GB's is the largest each slot can read.
For more information, check out the website below which has very detailed information on memory for various systems.
MacBook Pro Memory Information
SOURCE: Firewire audio problem
Hey Waterleo
I am running a very similar system. Black macbook and saffire not LE.
So this could be your problem. When you first connect the firewire cable to your mac from the saff you will see on the inputs a signal coming from nowhere. This is the mac syncing with the saff. Im pretty sure its the same with the LE but you must wait until your Line Mode(pad) lights turn green this means the two are connected. Try waiting for this it may take upto 3 or 4 mins sometimes depending if you are using the external powersupply or not.
If you have already done this and still nothing try this. FIrst plug a guitar into an input of the saff and confirm there is a signal being produced. If so your problem may be in your system prefs.
Apple menu --> System prefs----> sound
you will see a window with 3 tabs labled input, output and sound effects.
go to input and confirm that the saffire is in the below list and highlighted, the same for output.
Ignore sound effects.
Also i just looked at my saffire and i am not being rude now but i am assuming that your new to this tech. so there is a pot(knob) on the front for your saffire labled monitor, this is your main volume for the system.
hope this helps my friend.
