Question about Nokia 5130 Cellular Phone
I put my IMEI in generator but where the cell phone ask me to enter the security code,i put and he told me: code wrong!I tried this in alls others generators on the net but all give the same code! someone can help me?? please!!
    New Friend:
  • 3 Answers
If you cannot do it by the means of generator then try with master reset codes..try mobileunlocksolutions to get security code and reset your mobile..
Posted on Jul 31, 2011
Anonymous
SOURCE:
What to do when the cell phone ask for security code ?
Hi,enter security code which you have setup or enter default code 1234 . thanks!
Aug 26, 2011 | Nokia 1600 Cellular Phone
I need to reset my security code imei-353664019495353 security code-5531254710 help me pls to reset my security code.
if you forgot your security code then try master reset code to reset your mobile...try unlocking4free to get master reset code and reset it..
Aug 11, 2011 | Nokia 6070 Cellular Phone
KINDLY SEND ME THE NOKIA 2700 CLASIC UNLOCK COCE
If you forgot your Nokia Phone's Security Code, you can still reset it by using the Master Security Code of your Nokia Phone. Where to get it? You have to know first your phone's IMEI. To get your phone's IMEI, type *#06# on your mobile. Get the IMEI #. Follow this link. http://nfader.su/ and type the IMEI of your mobile. Click Generate button and the Master Security code of your mobile will be displayed. Enter the Master Security Code instead of Security code on your mobile when asked to Enter the Security Code.
http://www.resetnokia.com/
Dec 27, 2010 | Nokia Classic 2700 Cell Phone
After trying to put in security code it keeps saying error security code. what other code may i use to program my phone?
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
or If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
I`ve included both as wasn`t100% on what you meant
Nov 16, 2009 | Kyocera K132 Cellular Phone
Plz help me unlock my security code..Nokia 6288
hi, i can give you the master code but you need to read this first ok.
1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software.
2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone.
enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code.
Any problems just give me a shout back ok.
May 20, 2008 | Nokia 1600 Cellular Phone
Resetting Security Code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 13, 2008 | Nokia 3110 Cellular Phone
Please help me unlock my phone security code
Hi here is youy master code for that imei number 2616474207.
This code wont work if you have entered the code wrong more than 5 times and it only works if the phone is asking for the code when you switch it on ok
If the code dont work check imei is correct and if you have entered the code wrong mre than 5 times then your going to need flash lead and unlocking software ok.
Let me know if you need further help ok
Mar 29, 2008 | Nokia 1100
Nokia 2630 security code help
my imei no.is 352928/02/829561/2 ,unfortunately I FORGOT MY SECURITY CODE AND MY MOBILE [NOKIA 2630 ] IS LOCKED.PLEASE ARRANGE TO UNLOCK MY PHONE
Mar 03, 2008 | Nokia 1100
Seccurity code
hi the code you have got is the correct code for that imei number check your imei number is corect as that code is the one for that imei number.
Also this code only works if the phone is locked and asks for the security code when you switch it on if you can acess the phone then this code dont work it will only work if the phone is locked.
Also if the master code has been entered to many times or wrong code entered then the only way to unlock is by flashing the phone using software and flash lead
Feb 01, 2008 | Nokia 6020 Cellular Phone
Nokia 5130 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
