Blinking light ofdeath
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and issecured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of theset---remove the inspection plate and follow the wires to the right--you canunplug both plugs(most have two and they are marked with letters and differents so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---
These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.
If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this told you something you did not know rate this solution as very helpfulas I do this here for free.
SD TECH
SOURCE: green light blinks constantly. reset doesn't fix it.
This set has a lot of problems but I have news for you that I recently discovered from a authorized Mitsubishi repair center---
Mitsubishi has had so many problems with this set that now they sell a complete Chassis replacement for this set for about 200 dollars--You will have to go to a authorized center---no more trying to fix individual boards in this set...if you are in doubt--Google the model number and you will see all the problems this set has had---
Contact Mitsubishi and I think the best thing you can do is get the Chassis replaced--
If you have more questions about what I am telling you let me know---I think Mitsubishi is trying to avoid the class action lawsuits that are in progress against them for this model.
REGARDS, SD TECH
Testimonial: "Thanks for the tip. I left it blinking for 2 hours and tried reset again and it worked. But next time i'll use your tip to find the prob."
SOURCE: ws55511
Age of unit: About 7 years.
Rear Projection HD set, Mitsubishi WS-55511
Nature of problem: Blinking green light of death. Upon plugging the set back in after vacation, the green LED on the front of the set would blink continuously and the set would not turn on. I ordered the blinking green light kit from tvrepairkits.com after seeing this link on a tech forum, suggesting the capacitors were bad on the DM board inside the DM module. The kit arrived within days of ordering. The online instuctions were very detailed and could be followed even by a layman such as myself. Very detailed with lots of photos. My DM module was simpler to remove than the instructions indicated. It simply slid out after about five cables were disconnected from other boards. Buckled everything up and plugged the set back in. The blinking light started as it always had. It should normally go out in about a minute after plugging in to wall. I really didn't hold out a lot of hope that it would go out....and then....it went out! I pushed the power button and she fired right up! What a thrill! Including shipping, it cost me $45.90 to fix a set I paid about 3000 bucks for 7 years ago and was loathe to just throw away. I certainly wasn't going to pay nearly a thousand bucks to fix this set. It may be a little bulky, but the picture is beautiful as well as the sound system. You guys are great. A very reasonably priced gamble that worked. Watching a movie in HD while I type this, good to have my TV back after almost two weeks without it.
