I want to disconnect/remove an external GE water filter for a refrigerator from the copper lines that go in and out of the filter. They were pushed in place to install, but how do I get them out?
Install applicationsYou can transfer installation files to your device from a compatible computer,download them during browsing, or receive them in a multimedia message, as anOther applications© 2010 Nokia. All rights reserved.106
e-mail attachment, or using other connectivity methods, such as Bluetoothconnectivity.
You can use Nokia Application Installer in Nokia Ovi Suite to install an applicationto your device.
Icons in Application manager indicate the following:SIS or SISX applicationJava applicationwidgetsapplication installed on the memory cardImportant:Only install and use applications and other software from trustedsources, such as applications that are Symbian Signed or have passed the JavaVerified™ testing.
Before installation, note the following:
? To view the application type, version number, and the supplier or manufacturerof the application, selectOptions>View details.
To view the security certificate details of the application, selectDetails:>Certificates:>View details. Control the use of digital certificates in Certificatemanagement.? If you install a file that contains an update or repair to an existing application,you can only restore the original application if you have the original installationfile or a full backup copy of the removed software package. To restore the originalapplication, remove the application, and install the application again from theoriginal installation file or the backup copy.
The JAR file is required for installing Java applications. If it is missing, the devicemay ask you to download it. If there is no access point defined for the application,you are asked to select one.Other applications© 2010 Nokia. All rights reserved.107
To install an application, do the following:
1. To locate an installation file, selectMenu>SettingsandApplication mgr..Alternatively, search installation files using File manager, or selectMessaging>Inbox, and open a message that contains an installation file.2. In Application manager, selectOptions>Install. In other applications, selectthe installation file to start the installation.
During installation, the device shows information about the progress of theinstallation. If you install an application without a digital signature orcertification, the device displays a warning. Continue installation only if you aresure of the origin and contents of the application.To start an installed application, locate the application in the menu, and select theapplication. If the application does not have a default folder defined, it is installedin the Installed apps. folder in the main menu.
To see which software packages are installed or removed and when, selectOptions>View log.Important:Your device can only support one antivirus application. Havingmore than one application with antivirus functionality could affect performanceand operation or cause the device to stop functioning.
After you install applications to a compatible memory card, installation files(.sis, .sisx) remain in the device memory. The files may use large amounts of memoryand prevent you from storing other files. To maintain sufficient memory, use NokiaOvi Suite to back up installation files to a compatible PC, then use the file managerto remove the installation files from the device memory. If the .sis file is a messageattachment, delete the message from the Messaging inbox.
