SOURCE: Vizio VA26L - Tuner problem. After approx. 6
Take the set and reprogram it where one of the other sets are ok. Digital signal is not so forgiving as analog, also place one of the sets that is receiving that station in place of the not receiving one. It's possible that the signal level at the bad spot is on the border line and that model can't hold on to it. You may also check visio's web site for any software up grade to your model that you may have to down load.
SOURCE: Thmy samsung LN-T3242H - 2 years old - the picture
Hi:
Make sure under your audio options you are in stereo mode and not it SAP, (Special Aided Programing).
SOURCE: Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
