Question about Toymax Skyworth SLTV-2663A 26 in. LCD TV
Picture has become too big for screen - Toymax Skyworth SLTV-2663A 26 in. LCD TV
  • Toymax Master
  • 8,457 Answers
Used ur tv original remote,look for a button like View Mode,Picture Size,Aspect Ratio,Zoom.Pushes one of these buttons to changes the picture sizes to fit ur tv screen.
Posted on Jun 05, 2011
6ya staff
SOURCE:
A red blue and green line jus appeared across the screen of my 55 inch rca floor model big screen. instantly my picture and color become distorted
conversions are out....rca ... check for bad connections on circuit board around fryback xformer. check fuse by flyback xformer...fuse is shaped like a little plastic rectangle>>fuses should measure a SHORT when GOOD! Flyback Transformer is large in size and sends highvoltage to 3 picture tubes via a SPLITTER . easy to locate
May 19, 2010 | RCA R52WH73 Projection Television
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Yes my philips magnavox big screen tv is real
This TV needs the coolant changed. There is a layer of coolant between the face of the picture tube and the projection lens that degrades over time causing the picture to become less than perfect. This is a complicated repair because the picture tube and lens assembly has to be removed from the set and disassembled. Best left to a professional. Thanks for using fixya. Please take a moment and rate this solution.
Dec 04, 2009 | Philips Televison & Video
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
Top of tv screen has a black line and top of tv pict is squashed
Nothing you can do unless you have knowledge of Solid State Electronics Servicing. Looks like a couple of Capacitors in the Vertical Deflection Circuits have become bad.
Nov 29, 2008 | Philips Televison & Video
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Philips LCD picture too big
depending on your cable syayem there might be an easy solition right on your remote or as a setting in your box - they have zoom settings also that seem to superseed all settings your TV has
Apr 22, 2008 | Philips 42PFL5332D 42 in. LCD Television
Screene size
Ok this is called Blooming, this is when the signal intesifier becomes overloaded and the signal becomes overenergized and thus unviewable. This is not an adjustable proble even thoug for a time you can force the picture "shrink" but this is not a fix, it just hides the problem. I suggest that you fide a shop on FixYa that can look at you set and diagnose which components are at fault. You can also take the unit to a Tv shop in your area if that is easier for you.
Sep 08, 2007 | LG 17LX1R 17 in. HD-Ready LCD Television
Toymax Skyworth SLTV-2663A 26 in. LCD TV Logo
328 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
Eric Rotmil
Eric Rotmil
Marvin
Marvin
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
