Fuji FinePix A400 Digital Camera Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera does not turn on. I put fresh batteries in it, but that didn't help.
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Jun 06, 2011
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10835315
Points
101584
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
1helpful
Quit working after needing new batteries
The problem is with the battery connectors or an integrated circuit fault with your camera for which you need a replacement.
If you device is under warranty you can make use of it or else what you can do is get it serviced from a reliable service center.
Camera won t turn on
What model Vivitar camera? What type(s) of batteries?
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 • Cameras
My nikon coolpix s220 just stopped powering on. i charged the battery, but that didn't help. any suggestions?
If the camera was dropped and it does not turn on with a known GOOD battery the camera must have been damaged. When you dropped it the FIRST time and it worked you were lucky. Cameras do NOT like to be dropped.
2answers
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Why is the finepix games s2900 camera saying I should turn off the camera and put it back on again
I recently got this camera and it did the same thing to me. I found this site and did what quido777 said to do, smacked it on my leg, didn't work. But then I decided to check the memory card and took it out and put it back in, and now its working. I'm guessing it didn't detect the memory card for whatever reason. Before all of this I called tech support and they didn't know **** and wanted me to send it in. I'm glad I decided to fix it myself before going through all of that. But one thing is fore sure, after this camera, I'm never purchasing from Fujifilm again.
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
1helpful
3answers
Panasonic DMC-TZ3: one day it's working fine, next it won't power on. Tried the "Power Saver" reset technique posted ... didn't work. Battery is fully-charged.
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
2answers
My Sony DSC-T77 fell in the water 2 days ago. What will i do? Is there a possibility that it would still work? Pls help. Thanks
DO NOT TRY TO TURN IT ON! Remove the card and battery....try to dry out those compartments. Bury the camera in a bowl of uncooked rice for one week. Insert the battery and, with fingers crossed, try to turn it on. Even if it works, you may still have a problem with a haze over the lens elements when the water dried. You didn't say if the water was fresh or salt. If it was saltwater, the salt will continue to corrode the internal circuits of the camera.
2helpful
2answers
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
