Televison & Video Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and white), and same for video 3. the progression of the input "holes" are; (for video 1): yellow - white - red - white - red. (video two): green - blue - red - white - red. (video 3):same as video 2. when i plug in my game cube "yellow-white-red" chord thing into the following order of holes --"yellow chord=green hole, white chord = white hole, and red chord =second red hole" or either video 2 or video 3, i get black and white video.
Anonymous
Level 3:
  • Master 1,116 Answers
  • Posted on Jun 06, 2011
Anonymous
Master
Level 3:
Answers
1116
Questions
0
Helped
528063
Points
3536
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
2answers
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
How to install a video machine if I don't have the tv remote?
I'm assuming by "video machine" you mean some kind of DVD player or Blu-ray player or something of the like. I will explain how to install a DVD player. There are two major cables: one sends the video to the TV and the other sends power to the DVD player. The power cord plugs into the wall with the other end attached to the DVD player. The video cable plugs into the TV. If you have an HD television, the video cable will have a male HDMI piece that plugs into the TV while the other end of the cable plugs into the DVD player. If you don't have an HDTV, then you will use an RCA cable which has three prongs: Yellow, White, and Red. These three colored male prongs plugs into the corresponding color coded holes in the TV. The other end goes into the DVD player. When you have everything plugged in correctly and the DVD player is on, all you have to do now is change the TV input. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc. Keep going until you are on the correct input to see the DVD player menu. Good luck!
2helpful
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
3helpful
3answers
When I hook my dvd player up using the red white and yellow cords, the sound will come in but not the video but I have no remote. Please please please help!
The yellow must go to the video and the sound L&R to the audio inputs. If there is no video after selection of the AV, then it is possible that the input video amplifier is faulty. If there is a second AV2 port then use it or else you might need a modulator to connecct vis the RF input.
Other wise the set must be opened to check for failure off the video amp, protection diode at the input.
Just got dish a week ago everything fine. Yesterday the power went off and now the main TV has arch screen and three different colors on everything on the TV and TV 2's screen is just blue
wvpotts0,
Are you still having problems with your receiver? Depending on the type TV you have, TV 1, on an older TV will use channel 3 of 4. A newer TV will have an input setting. If you have the TV remote, press either the "input", "source", or "tv/video" button to cycle through the input settings till you find a picture. Make sure the green, blue, and amber lights are lit on the receiver. TV 2 should be on channel 60 or 73. I hope this helps.
Ray Calo
DISH Network
How many wires go from DVD to TV and what colors are they?
Ok. If you have a tv that has a five hole input (green, blue, red, white, red) this is the preferred hook up. That cable is called a component cable. The green blue and red part is for video and the white is audio left and the red is audio right.
If your tv does not have the five hole input it should have a three hole input. Those colors are yellow, white, and red. This is called a composite cable.
You just match up the colors that's all. Your tv should have an input or tv video button on the remote control that would allow you to switch inputs or you may be able to get to video 1 and video 2 and etc by using the channel up and down button and going lower than channel 2.
5helpful
2answers
I need a diagram on how to hook up my vizio tv to a tuner, direct tv and a dvd/vcr
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. Colored Yellow, (Video) Red, & White. (Audio) AV. OR If you haveSCART Connection Sockets, it's a big Black Socket at rear of unit(s), you get a SCART Cable.& It's all inside. Now some units, use a standard called Component Video, that uses, a Green, Red, & Blue Plugs. Also we have with the "Component Video" it is marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red &White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
2answers
I get cable tv and it works fine. How do I hool up a vcr and do i have to put the tv on a certain channell for it to play . Cannot read the manual, the printing is to small.
No, the VCR hooks up Via the, sockets, Yellow, Video, and the White & Red Audio, connections, color to color. Then you select an EXTERNAL input. You do NOT "Tune" a "Channel" for this to work. It gets the signal via the Audio Visual port, usually at the side, front or rear. Also some sets can use SVHS connector. This is a small round multi pinned socket on the set, this too is an External, called composite Video. input.
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
