Sqeaky paper feed
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=238800&prodTypeId=18972&objectID=c00001617
the HP site for your printer
Over time, particles of toner and paper accumulate inside the HP LaserJet 2300 series printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
Clean the paper path and print-cartridge areas every time that the print cartridge is changed or whenever print-quality problems occur. As much as possible, keep the printer from dust and debris.
Cleaning the outsideback to top of page
Clean the outside of the printer with a cloth that has been dampened with water.
NOTE: Do not use ammonia-based cleaners on or around the printer.
Cleaning the paper path and print-cartridge areasback to top of page
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
Use the following steps to clean the paper path and print-cartridge areas:
1.
Turn the printer off and unplug the power cord.
2.
Open the top cover.
Figure 1: Top cover opened
example
3.
Remove the print cartridge.
Figure 2: Print cartridge removed
example
CAUTION: To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.Be careful not to touch the transfer roller (the black, rubber roller located underneath the print cartridge). Skin oils on the roller can cause print-quality problems.
4.
With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity. Make sure not to touch the transfer roller with fingers, as the oil can contaminate the roller, resulting in print quality defects.
Figure 3: Paper path area and print cartridge cavity
example
5.
Reinstall the print cartridge and close the top cover.
Figure 4: Print cartridge reinstalled
example
NOTE: If the print cartridge is difficult to reinstall, make sure that the registration plate has been flipped back down into position and that the print cartridge is pushed firmly in place.
6.
Plug in the power cable and turn on the printer.
Cleaning the fuserback to top of page
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of print jobs.
To ensure optimum print quality, HP recommends using the cleaning page every time that the print cartridge is replaced or on an automatic pre-established interval.
The cleaning procedure takes about 2.5 minutes to complete. A message (either CREATING CLEANING PAGE or CLEANING) appears on the printer control panel display while the cleaning is taking place.
NOTE: Use plain paper to print the cleaning page. Please note that this is a two-step process. First print out the cleaning page using the following directions, then follow the directions on the cleaning page itself to reinsert it back into the printer to perform the cleaning.
Use the following steps to run the cleaning page:
1.
If the printer model includes a duplexer, open the rear output bin.
2.
Press example(Select button) to open the menus.
3.
Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE, and then press example (Select button).
4.
Use example (Up button) or example (Down button) to scroll to PRINT QUALITY, and then press example (Select button).
5.
Use example (Up button) or example (Down button) to scroll to CREATE CLEANING PAGE, and then press example (Select button).
6.
Perform the following to complete the cleaning process.
1.
Remove all paper from Tray 1.
2.
Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE and then press example (Select button).
3.
Use example (Up button) or example (Down button) to scroll to PRINT QUALITY and then press example (Select button).
4.
Use example (Up button) or example (Down button) to scroll to PROCESS CLEANING PAGE and then press example (Select button).
5.
Load the cleaning page created in step 5 above into Tray 1 with the print side down and the arrow towards the printer.
7.
If the printer model includes a duplexer, close the rear output bin.
Let me know if that helped.
Good luck,
Tim
