Firstly check lid lock switch. A variation in flow due to intermittent fault will cause a read fault in control module to show power cut. If this is the cause then the "powercut" reference in the display will likely only show when lid lock is enabled or shortly after during the course of that particular cycle. Failing that then clean all plugs to contol module. Failing that check all connections to pump ,motor . Rps if applicable to model. Failing all of the above then check for fault in control module. Focus attention to a possibly present "link" switch hidden in an inconspicuous spot on the control board. If complete failure then replace the board . Soze machine and hopefully it works.
It sounds like you may have a loose connection somewhere and you are loosing power to the machine, worst case scenario there an issue with the motor controller module.
I dont understand the door flop down, these should lock unless of course the motor locking unit is buggered causing the system to restart.
