Question about Pyramid PDVD78 Car DVD Player
When I see video of my radio dvd pd 733bt pyramid, the display says Frease the following: parking brake audio only! what should I do to get out of the sentence is the display?
    New Friend:
  • 51 Answers
That is because it has a safety on it to where you can only watch videos when in park. It doesnt want you watching movies while driving. Easy to bypass if you know what your doing. There is probably a wire on the back of the stereo that is in a bundle that you did not use? It should be relatively long. Maybe add a bit of length to it with some more wire and hook it to the ground on your battery if that doesnt work put it on the positive. Sorry i remember doing this in my camaro dont remember if its pos or neg but you are suppose to hook that wire to somthing on the parking break. Hooking it straight to the battery will bypass the parking break safety.
Posted on Jun 07, 2011
6ya staff
SOURCE:
Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
Sep 24, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
I JUST BOUGHT THIS TRUCK THAT HAS A BOSS RADIO IN IT AND WHEN I PUT A DVD IN IT WHILE IT'S PARKED IT SAYS "WARNING". I'M NOT SURE IF IT'S BROKEN OR WHAT.
you can't watch a video on the system unless the parking brake is on. you have to buypass the parking brake system in order to have a video on while driving
Feb 09, 2011 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
Dvd video i can,t see it is a messagees :"parking off"
You need to make sure the parking brake lead is hooked up from the radio to the parking brake, and that the parking brake is engaged.
Feb 06, 2011 | Kenwood KVT-512 Car DVD Player
My avh-p4000 dvd is not displaying video when i insert dvd's I only recieve audio is there a switch that I need to set to get both audio and video
there is a light green wire that needs to go to the parking brake. video will not work unless the parking brake is on. this is for safety reasons and it is illegal for the driver to view videos while driving.
Jan 18, 2011 | Pioneer Car Audio & Video
My new radio plays every thing but when i put a dvd it says warning please stop watch vedio player . you can hear the movie but there is no picture
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
Oct 18, 2010 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
How can I watch dvd on my kenwood radio while I drive
you have to bypass the parking brake safety switch. Basically, right now it is wired to the ground on your parking brake. Figure out where it is by following the wire from the head unit. Disconnect it, and connect the parking brake wire to the ground for the radio itself.
May 14, 2010 | Pioneer AVIC-D3 Car DVD Player
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
How To Bypass The Brake Switch To Watch Videos While Driving?
Clarify please-does the screen show "Audio Only" when a DVD is inserted? If so, this is because the parking brake lead is not set up to work. Normally, the green lead connects to the parking brake negative on the car. This means you don't get video unless the parking brake is set. To bypass this, you need to wire the green parking brake lead to one terminal on a toggle switch, then you run a wire from the radio ground lead to the other terminal. toggle the switch up and down and you should have video. You can get a pretty small toggle switch and mount it in a concealed place.
This is by no means advocating watching video while driving!!!!
Apr 12, 2008 | Clarion (VRX765VD) Car DVD Player
Kenwood ken
Irst thing to check is to Make sure Parking brake lead (green) is being grounded properly otherwise safety message should appear on display notifying you and You will get no DVD video only audio Refer to owners manual on this issue. If that does not do it you may try resetting unit look for small Round hole on front of radio. Depress with pen point.
Just a couple guesses.
Jan 17, 2008 | Kenwood KVT-617DVD Car DVD Player
Pyramid PDVD78 Car DVD Player Logo
109 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Alphanso Tee
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
