SOURCE: Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
SOURCE: Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
SOURCE: My camera shows CARD LOCKED
Try taking the card out of the camera and clicking the side of the card - there may be a little gap on one side of the card or a small button that you can slide up and down and then reinsert your card.
SOURCE: My Pentax K100D has suddenly stopped working. It
Hi there as per your mentioned sound or noise is says that the problem create by your camera lens guide pin. Its damaged or dislocate. So i also suggest you to visit the service center. Thanks.
SOURCE: Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
