ION Audio Ion iED05 USB Digital Drum Kit Logo
Posted on Jun 07, 2011
Hi! just now bought a secondhand idm05 with no cd driver,is there anywhere,to download the programe? thanx rob
Hello. i bought the axium 25 when i still had a powerbook. and that is all the drivers on the cd support. so i need a driver software for an intel mac or newer mac. i cant find anywhere. thanks!
Axiom keyboards are compatible with PC as well as Mac.
I don't know what DAW you are using but Axiom is compatible with several.
Take a look at Avid's hompage to solve your problem, lots of configurations and downloads.
I am sure you will find the answers right here :
http://www.m-audio.com/index.php?do=products.directlink
Regards
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Hi. How do I fix a CD deck that wont open if I press eject? The deck refused to open with a CD inside. The deck wont play the CD if I press play and wont eject if I press eject. please help. Thanx TC
To retrieve the CD safely, the safest way is to open the unit. A common problem is that a tiny belt from a motor that drives the eject deteriorates and slips so there isn't sufficient drive to move the mechanism. The unit is probably in a mode expecting to eject and has commanded the motor but it doesn't complete... Do as I say and open the unit to do the retrieval. Then get unit serviced.
I HAVE YPT-400 BUT DONT HAVE CD THAT SUPPOSE TO COME WITH IT IS THERE A PLACE WHERE I CAN GET THE SOFEWARE ON INTERNET
Contact Yamaha America parts dept under "support". There may NOT be anywhere to download what you are missing. It would be best to get an original CD if you can.
1helpful
2answers
Usb device not recgonized
Did the keyboard come with a cd?If so(which it usually comes with),put the cd into your drive and it may just run the drivers.If nothing happens,leave the cd in the drive and go to control panel/install new hardware tab in the control panel.Then it should display a list of programs on your computer with a question mark next to it to describe that it is not running correctly(make sure the keyboard is plugged in when you do this).Click on the line that says your keyboard or it may say something along those lines...Then it will opt you to use the internet or install the program manually.Select manually and it should search for the driver,and if your cd is still in the drive,it will find any driver on said cd and install it so your keyboard will work.
Any of these keyboards usually come with software anyways,so it should be on the cd.If you dont have one:look up casio on google and see if you can get the drivers from their knowledge base.
1helpful
Hii
Hi
Find out the make of your sound card in control panel/system and either Google the manufacturers website and see if they have a download section or go to http://www.soundcard-drivers.com/ and see if the make is listed there
Cheers
Dave
Sep 27, 2008 • Music
Top ION Audio Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an ION Audio Music Expert? Answer questions, earn points and help others
