Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Hi i have a sony lcd tv model number KLV-40S200A and it wont turn on just flashes a red light (LED) on standby 3 times ? its about 4 years old i was just wondering if it was a voltage problem or something to do with a lamp replacement cause i cant find any info on these modes thank you your help would be really appreciated
  • 597 Answers
I would guess your power supply board is bad. Plan on replacing the power board .
Posted on Jun 08, 2011
6ya staff
SOURCE:
Sony LCD TV Red LED light constantly blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 06, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
Jan 19, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Sony klv 26s550a red light blinking problem
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 08, 2013 | Sony KLV-26S550A 26 inch Multi-System HDTV...
Sony KLV-46S200A LCD TV doesn't turn on, it remains blank with the red standby lighthouse blinking 4 times.
According to the service manual page 6. four flashes is "Backlight Trouble" so if its the light it self or Backlight Inverter Board i cannot tell you.
Service manual can be downloadet here.
http://elektrotanya.com/sony_klv-26s200a_klv-32s200a_klv-40s200a_klv-46s200a_chassis_wax2.pdf/download.html
Feb 03, 2013 | Televison & Video
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Problem with a Sony KLV-26HG2 LCD tv switching on for 2 secs then switching off/ flashing standby light
http://electro-medical.blogspot.com/
Apr 12, 2012 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Hi I have a Sony Bravia KLV-40S200A which wont turn on. The standby button flashes five times then pauses for about 4 seconds then flashes again. Any ideas?
Diagnostic Test Indicators
When an error occurs, the POWER LED will flash a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first.
LED ERROR DESCRIPTION CODE
1 Supply Voltage Trouble Panel 5V UNReg (10.5V)
2 DE5V Voltage Trouble FE5V (DCALERT2)
3 Voltage Trouble D3.3V/D2.5V/D1.8V. (DCALERT1)
4 Backlight Trouble
5 Main Supply Voltage Trouble (17.5V.DET)
6 Speaker Applied Voltage Trouble
7 Monitor an Increase in Inside-Temperature (esp. on the panel side)
8 Trident IC Trouble
Apr 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I had a similar problem with my 42 Inch Philips 42PLF5432D/37 LCD HD TV. It would turn on but then shut back off after about 10 seconds. Then it wouldn't turn on at all. The problem was a bad capacitor. Several bad capacitors. They are inexpensive and fairly easy to replace if you don't mind digging around in the back of your set and soldering some new ones on your Power Supply Board. Or take the less inexpensive route and look for a whole new Power Supply Board. Good luck. Hope this helps.
Dec 08, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv will shut off and red light will flash 3 times
If its Sony KDF-42WE655 TV that goes to standby and LED blinks 3 times then check Lamp Door that seems not fixed properly.
That happens when lamp replaced in TV.
If its different model number TV, let me know exact model number.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KLV 40S200A
If you watch how many times the light flashes and then relay that to your local authorized sony repair centre they will tell you what is likely wrong with the TV. Have you unplugged, left for a couple of minutes and re-plugged?
Sep 07, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
391 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
